Hydrolic leak
George
08-09-1999 08:05:23
I have a Sherman 54 series back hoe and the long
cylinder that operates the middle pump is leaking.
At the top end of the cylinder there is an inner
metal cylinder end that is removeable? with a
large Pin type wrench. Then there is a smaller
ring which is also removeable with a slightly
smaller Pin wrench. I thought the smaller (outter) ring was the seal, but it is not leaking.
The inner larger ring is leaking between it and
the cylinder.
Question,
How to make a field repair to stop the leaking...
Any Help???
George
Charles
08-11-1999 20:21:18
 Re: hydrolic leak in reply to George, 08-09-1999 08:05:23
Sounds like a packing seal leak on the ram packing. Because of the leakage and the tools it might be better to remove the cylinder and take it to a hydraulic shop. If the polished shaft is not grooved or scratched (still has it mirror finish) and you have the pin spanners then you can get the packing (teflon/rubber/etc.) from the same hydraulic shop and do it in the field. Just remember that even with the engine not running there can be pressure. Move levers to set unit on the ground and bleed off this pressure.
