DB996 TCU
Jamesmartin
08-14-2004 07:29:23
Elmer, I'm having trouble getting my 3pt to lift in TCU. If you would, please look forward to page 9 and see if you recognize my problem.
Thanks, James
Elmer
08-14-2004 20:06:32
 Re: DB996 TCU in reply to Jamesmartin, 08-14-2004 07:29:23
Try taking the cover off where the rate of lower knob is and adjust the 5/16 nut on the rod. Tighten it in a little. With the three point hitch in full raise with the lever against the spring, it should then drop one inch at the lift link bolt when the lever is moved to rest position by the spring. The lift link bolt is the bolt that attaches the lift link to the rock shaft. Hope this helps!
