lower links and toplink questions (David Brown Oli
Herb
08-13-2004 06:45:26
third party image
Greetings!
Question:
1) Is this an orignal drawbar?
2) If I remove the drawbar,can I just attach the lower links,so the unit becomes a 3-pt hitch?
3) If this is possible,what size toplink can I use?
4) If I buy lower lift links,is there a particular length?
Originally,the toplink was a single ended and overload release unit. Unable to find a replacement.
The tractor is a David Brown,disguised as an Oliver 500.
Serial# 100875 D Spec# VAD/2/OA DAVID BROWN Stamped ON ENGINE BLOCK
Regards,
Herb
Elmer
08-14-2004 20:08:43
 Re: lower links and toplink questions (David Brown in reply to Herb, 08-13-2004 06:45:26
sent an email to you, not sure if it made it to you. Was doing some digging here in the barn. I have a full drawbar and two three point draft arms. Depends on where you live. The drawbar assembly is heavy to ship!
Herb
08-15-2004 11:32:34
 Re: lower links and toplink questions (David Brown in reply to Elmer, 08-14-2004 20:08:43
Don't need the draw bar. Sent email to your addy.
Elmer
08-16-2004 04:49:38
 Re: lower links and toplink questions (David Brown in reply to Herb, 08-15-2004 11:32:34
Did'nt see any email here. You sure you got the address right. Some of my email usually gets to my niece.
Paul W
08-14-2004 05:01:53
Herb; Your tractor looks identical to my DB 950. The draw bar on mine bolts directly to the under neath of the tractor and the two outer arms for the three point hitch are attached to two arms that swing on the same pins as your draw bar. Yes the center link is longer than normal but I was able to find a used on at the salvage yard. Hope this helps ; Paul
Herb
08-14-2004 10:47:26
 Re: lower links and toplink questions (David Brown in reply to Paul W, 08-14-2004 05:01:53
We'll I'll be darned!
I got so many different opinions about this "contraption",I didn't know what to think!
Your comments are greatly appreciated and I will adhere to your advice.
Kind regards,
Herb
richard
08-14-2004 15:20:27
 Re: lower links and toplink questions (David Brown in reply to Herb, 08-14-2004 10:47:26
Your tractor is a D.B. 850,the 950 was badged as the Oliver 600.The drawbar is a proper D.B. unit but as you have already been told it can be removed and standard D.B. link arms fitted,most tractors have a drawbar frame bolted up under the transmission casing,your drawbar was optional.
