Info on VAC
Slomoshun
08-08-1999 10:07:50
Can anybody give me some basic info on a VAC. I am looking to buy a tractor and saw this model 4 sale. New rear tires and paint. what should I look for? What is something like this worth? thanks for your assistance.
C. Amick
08-09-1999 09:37:44
 Re: Info on VAC in reply to Slomoshun, 08-08-1999 10:07:50
Did they give the model year? It may or may not have an Eagle Hitch which is Case's version of a three-point hitch. The motor is likely a 148 cubic inch gas engine. They sell for around $1,200 if in good condition. It does not have a live power take off. What kind of work are you planning to do with the tractor?
Slomohun
08-09-1999 18:33:21
 Re: Re: Info on VAC in reply to C. Amick, 08-09-1999 09:37:44
I do not know the model year. No hitch, and no live PTO. I dont have much use except some moving of trailers and perhaps a belly mower, Is this a reliable unit. Anything I should look out for?
Thank you,
Slo
C. Amick
08-10-1999 09:48:49
 Re: Re: Re: Info on VAC in reply to Slomohun, 08-09-1999 18:33:21
My dad has owned a 1948 VAC since 1969. It has always started real well and has been very dependable. May need to drain gas tank and remove rust if it has been sitting for a while. The is a die mounted hoist that is ran off the bel pulley shaft, may want to check to see that this works. You may need it to lift the belly mower.
