LA questions
Case1950
08-12-2004 09:32:49
Where is the S/N plate located on LA"s? Also if it is missing, is it stamped on the engine in the same place as DC"s?
I"m going to look at a "40"s LA and LAE, they have been sitting inside for 30 years, engines are supposed to be loose. The tractor is an all-fuel. If they are in decent shape what on average would be a good deal for both of them? (I know the last question is kind of hard to answer)
Thanks,
Case1950
caseman-d
08-13-2004 17:59:38
 Re: LA questions in reply to Case1950, 08-12-2004 09:32:49
The LAE engine should have a serial number plate on the valve cover, or at least my DE engine did. Serial number for the LA should be on the same panel as the guages.
caseman-d
Al
08-14-2004 07:06:05
 Re: LA questions in reply to caseman-d, 08-13-2004 17:59:38
My '48 LA has the serial number on the dash near the gauges.
Brian in Ohio
08-13-2004 18:58:31
I have an LAE, and the serial number plate for it is riveted on the carb side on the radiator supprt, right next to the starter button.
Brian in Ohio
08-12-2004 18:29:29
The serial number should be stamped on the carb side of the engine, on the flange where it mates to the transmission.
Case1950
08-14-2004 18:09:49
 Re: LA questions in reply to Brian in Ohio, 08-12-2004 18:29:29
Thanks everybody, Found the S/N on both units. Tags were missing on both, but found them on the engine flange. The LA was a little to ruff for me to drag home, wasn"t in bad shape, just to much of a project for me.
Thanks again,
Case1950
RobertTX
08-16-2004 06:33:08
 Re: LA questions in reply to Case1950, 08-14-2004 18:09:49
If you have decided not to get the LA, could you tell us where it is located? Thanks.
Case1950
08-16-2004 10:25:12
 Re: LA questions in reply to RobertTX, 08-16-2004 06:33:08
It is located near Dalton Georgia (North Georgia). If you want I can give you the guys name and #.
Case1950
