magneto
Mike O.
08-11-2004 21:48:19
I want to take my mageto off but I'm not sure where the mounting bolts are. I have a 36' RC. There is a lower radiator hose that runs up against the bottom of the mageto, so i can't really see under it. Also, is there anything that I should know before taking it off. i.e. having to reset the timiming on it.... when i put it back on. Should I leave it up to someone who knows about mageto's to take it off and put it back on. I want to send it to someone to have it checked. Thanks for your help!
Paul Miller
09-06-2004 14:16:59
 Re: magneto in reply to Mike O., 08-11-2004 21:48:19
I have a 1938 case RC that I just restored and I had to replace the mag. What I did was make sure the number 1 cyl. was at TDC on compression stroke and set the mag to fire number 1 plug wire at that time. After I had it set I rechecked it by turning the engine over and listen for the mag to click at TDC. Keep plug wires off until ready to start. I hope this helps.
