SC power lift
fredct
08-11-2004 19:14:47
Help - I unbolted the power lift from the rear housing to reseal the gasket and now I can't get it to slide back on (I did not even take it all the way off - just slid it back) Any help on what trick i need to get it to go back would be appriciated. Thanks, Fredct
C. Amick
08-12-2004 09:48:12
 Re: SC power lift in reply to fredct, 08-11-2004 19:14:47
The end of the pump shaft has a slot cut across it. There is a small coupler that sits in this slot on the end of the shaft that ties it to the tractor shaft. When you slid the pump back, something must have turned a little. There is nothing to hold the coupler in place except the slot and if you aren't carefull it will fall out. I would hold the pump up against the tractor and have someone turn the engine by hand with the PTO engaged to see if you can get the slot lined back up with the coupler.
