I'm welding the heads myself!
ThatOtherGuy
08-10-2004 16:53:17
Im going to try and get these heads for my Case 410 welded up. The shop in town said it would be real expensive for them to fix it, but all I need is the thin welding rod-that I have. I already got one crack all welded and ground down. I plugged the water ports and put water in the head but that one still leaks a little bit. So I got to add more weld and re grind it. By the way, I'm using a lincoln stick welder and a skill 4" grinder. I think I can get it sealed.
I thought what the heck, I cant get core credit or sell them cracked, so I decided to weld them up.
Now I'm not welding them so I can temporairy patch it and sell it-Im not that kind of business person. If I can get it welded I'm going to put a blade or get the loader the previous owner has for it. I will use it.
So-crazy, stupid, time wasting or a good idea? Let me know what you think of my idea welding it.
ThatOtherGuy
ThatOtherGuy
08-12-2004 17:14:12
 Re: I'm welding the heads myself!-outcome... in reply to ThatOtherGuy, 08-10-2004 16:53:17
It didnt work. Turns out the heads are cracked all the way across and up past the valve seat. So the heads are no good. That's why the shop said it couldnt be done.
george md
08-12-2004 18:50:42
 Re: I'm welding the heads myself!-outcome... in reply to ThatOtherGuy, 08-12-2004 17:14:12
other guy, If you grind out the trash arc weld , you might be able to talk one of the cyl head welding shops into repairing them. Two that I know about are,
Chapin cyl head - chapin ill
Diesel cast welding -Blaine , Mn
Both do preheat oxy/acet cast iron welding.
george
Johnski
08-11-2004 15:26:01
 Re: I'm welding the heads myself! in reply to ThatOtherGuy, 08-10-2004 16:53:17
Good luck with the welding. If you still have some small leaks after welding the cracks up then you can cover over the welds with solder. Use the stick type like they use on old cars and just sweat it over the welds. I had an old Autocar with a 2' crack on the side of the block and it lasted for years. HTH :)
INCase
08-11-2004 10:31:26
I posted this a while ago Muggyweld "susposedly" has welding rods that will even work on contaminated cast exhaust manifolds. Haven't tried it yet thought. Let us know how you made out. are you gonna take the heads in and have them prof. tested (magnafluxed) ?????
http://www.ytmag.com//case/messages/57029.html
Illini Case
08-11-2004 06:04:07
A year a go I had a 10" crack in a case gas head. Used "soft nickel" rods, ground the weld down,got a good sealing finish with good ole JB weld (it laid smooth on the weld surface. This repair was on the outside of the water paasage so it just had to hold water in the head and not hold motor compression. The repair worked perfect. Just remember to not weld over 1/4" at a time---stitch weld per say.
george md
08-10-2004 23:58:02
other guy, Like Dkase says , the odds of success using
arc weld are some where between nil and zilch.
Any shop that welds heads or other heavy castings
does not use arc weld , they use oxy/ acetylene
and cast iron (cast iron in a stick) rod. The
welding is always done in a fire brick oven to
heat the head to at least 900 deg F(dull red )to
get past all of the expansion and when welded with cast iron rod all contracts at the same rate. The reason not to use arc weld is that cast is not
ductile and cannot give or stretch as it cools.
The nickel contracts at a much greater rate than
the cast and has at least twice and in most rods
3 times the tensile strength of cast , there fore
you will more than likely have a hair line crack
either in the weld or next to the weld . I do oxy/acet cast welding and here is a link
to some repair , mostly manifolds .
http://www.imageevent.com/gmachine
Below will be a link to several pages of info on cast iron welding by a fellow that does cast repair all the time , and holds several pattens on lacing products for cast repair. You will find that he says that your best choice for welding
is oxy/acet , next best is brazing , and the worst choice is arc welding . I have been in several of the cylinder head repair shops and all use torch and preheat.
george
Chris Brown
08-10-2004 20:33:47
I had an IH td9 crawler loader I got it hot and cracket the head in three cylinders. I welded the cracks up myself with 99 percent nickel rod, I had to have the machine shop put in a valve seat, because I welded to close to it. But The welds held fine. I had planned to use some bars leaks or similar But it did'nt need it. Go for it, It'll probably work ,even if it does'nt what have you got invested $10 worth of welding rods and 2 head gasgets,big deal. Thats a small price on a gamble to get it useable.
DKase
08-10-2004 20:03:06
I will give you a 1 in 1,000,000 chance of being successfull. Getting cast iron air tight with no tiny cracks is almost impossible. Holding the compression with the severe temperature changes is thousands of times harder. Watch your oil very very close. If it does leak you could end up spinning a bearing and wrecking your crankshaft. If it leaks the sleeves and pistons will be shot for sure. I hope you understand that you are gambling much more than the cost of a set of heads. Good Luck
Eddie in Ky
08-10-2004 19:53:29
Hey guy, I'm a firm believer in the "what the heck have I got to lose" theory. Best of luck to you.
Jerry W
08-10-2004 19:25:21
I hope you are preheating the real head good and letting it cool real slow. You have to use a rod compatable with cast iron like nickle or stainless. In you application I believe nickle to be the better choice as it is not as hard and less sensitive to heat.
There are a lot of composite rods out there made specifically for your situation.
Good luck.
Jerry
Pat T
08-10-2004 18:12:22
Hey, nothing ventured nothing gained! Hope it works for you. We welded the center exhaust maifold of our 1570 this spring with certainium (sp?) rod and a lincoln 225 welder. Worked, but we found you get some shrinkage from the welding, had to grind the mounting holes out to get them to clear the studs. Watch out for that, I guess. Not an expert welder at all, but wanted to pass the work about the shrinkage. Good luck!!
