burned up 1070
Albert
08-10-2004 16:26:25
What would a very badly burned (cab/fuel tank fire)1070 be worth, most of the fire concentrated to the rear of tractor, fuel lines burnt up to the engine/pump components, but I think the pump is ok the rubber hose burnt through? What possible trans/engine components are bad? It is a P.S.
AllanC
08-10-2004 22:08:30
 Re: burned up 1070 in reply to Albert, 08-10-2004 16:26:25
I doubt it's worth it. Check the hydraulic stuff - valve body for the powershift is on top of the transmission, under the cab floor. Pipes to it, filter units on right side. If this stuff is all fried I'd say it's a parts machine.
