410 Head Hunting not going well
ThatOtherGuy
08-10-2004 13:53:52
Well I found some heads. Problem is they both want well over 200 a piece-and thats without any valves. I don't have that much money to put 700 in a pair of cylinder heads. Is there anyone that knows of someone that has heads for my Case 410? I would like to fix it, but if I can't find a pair of heads that are cheaper and complete, I might just have to sell it. I can re-grind the valves and seats, so that wont be a problem. The ones I got are both cracked between the valves. And all the valves are cracked. They leak a lot of water into the pistons but not hardly anything into the oil. After I shut it off, I have to completely drain the cooling system or water will get in the oil.
Any help?
ThatOtherGuy
Chris Brown
08-10-2004 20:43:02
 Re: 410 Head Hunting not going well in reply to ThatOtherGuy, 08-10-2004 13:53:52
I don't know where you are located but, Call Jim a call at (573)682-5253 He is in Centralia,MO He is a big case man and I am sure he has some pieces laying around for you. Arent those heads the same as a 930,830,730 and many others? Should be plentiful if they are the same.
Leland
08-10-2004 18:40:59
try calling the guys in chapin ill they may know who has a set or find a guy in easton ill named rusty riggins he may know were a pair is the chapin ph#hould be in most fram mags in classifed ads
