Serial numbers
Cheryl Cookson
08-10-2004 09:14:54
My dad found a tractor and we don't know what year it is or the model. The following serial numbers were found on it... VT161,571-51236,VA1 or YA1, VT328
If anyone could help that would be great!
Joe (Wa)
08-10-2004 13:59:08
 Re: Serial numbers in reply to Cheryl Cookson, 08-10-2004 09:14:54
VT161 & VT328 are casting numbers for the shifter cover plate and engine block respectively in most VA series tracctors.
VA1 & YA1 are most likely VAI, meaning the tractor is the industrial model in the VA series.
57151236 may be the tractor serial nr if it is on a plate located on the instrument panel, however there are too many digits. There should be 7 digits in the serial nr. The first 2 digits minus 4 will be the model year I.E. if the first two digits above are correct 57 - 4 = 1953.
Joe
