SC oil leak
David in Wis.
08-09-2004 18:04:48
My sc leaks oil by the starter. Any idea? Also, were is the serial number on the side of the tractor. Picture would be nice. The tag is gone.
C. Amick
08-11-2004 13:30:35
 Re: SC oil leak in reply to David in Wis., 08-09-2004 18:04:48
The starter has a gasket on it. It is still available from Case/IH. It is a very thick gasket. You may be able to make one.
todd hamilton
08-09-2004 18:42:40
Check the seal on the shaft for the belt pulley. SCs have a bad habit of leaking there and it is pretty close to the starter. If it is that seal and you have old oil in the transmission replace it with new 85W140 gear oil (it caused my seal to stop leaking). The serial number is imprinted on the bell housing flange between the engine and transmission but I forget which side. It is either the right or the left!:^)
Fredct
08-09-2004 19:47:00
 Re: SC oil leak in reply to todd hamilton, 08-09-2004 18:42:40
The serial # is on the left side behind the manifold. Regarding the oil lek, do you have the gasket on the starter? Good luck, Fredct
