CASE 530D
JIM
08-08-2004 12:25:40
CAN NOT START DIESEL ENGINE. SAT FOR OVER YEAR.
TURNS OVER FINE.POSSIBLE FUEL PROBLEM. FUEL GETTING TO INJECTOR PUMP, NEW FILTERS. POSSIBLE AIR IN SYSTEM SO REMOVED SOME SCREWS ON INJECTOR PUMP TO BLEED SYSTEM, BUT NOTHING.DID THIS ONCE WHEN RAN OUT OF FUEL AND IT WORKED.ENGINE SMOKES
WHEN TRYING TO START. BUT NO SMOKE THIS TIME.
PLEASE HELP?
WHAT AM I DOING WRONG?
THANKS JIM
Jim M
08-14-2004 19:08:47
 Re: CASE 530D in reply to JIM, 08-08-2004 12:25:40
I worked on one with the same problem. The injection pump shop told me to remove the top cover and try moving the rack rod back and forth to free up the stuck rack. I did it and reassembled and it started. Jim
John Saeli
08-08-2004 13:58:59
Hey Jim: I'd "crack" the lines @ the injectors and see if fuel is making it that far.
