engine identification
tbair
08-07-2004 20:55:49
I just purchased a 530CK backhoe. The rocker arms
and valve train were making some noise so I figured the valves needed adjustment. When I removed the valve cover the top end of the engine was dry and rusty. The rocker arm shaft had been
removed in the past and the hollow bolt wasn't
put back in the proper place. The previous owner
said the engine had been replaced and was larger
cubic inch than stock. I need a rocker arm shaft and rocker arms. The casting number on the head
is G2084 and on a tag on the right side of the
engine near the oil filter is 2062864. I did a search of those #'s in the archives and found that
the head was used on 630's but I'm not sure if that is enough info to get parts. If anyone can
tell me what engine this is or direct me as to where to find parts I would be much obliged.
Thank You
