300 fuel sending unit
Lincoln
08-07-2004 19:33:59
Anyone know where I might fing a replacement fuel gauge sending unit for a Case 300? How can you test one or have one repaired?
Joe (Wa)
08-08-2004 10:18:58
 Re: 300 fuel sending unit in reply to Lincoln, 08-07-2004 19:33:59
The original gauge and sender were Stewart Warner. The sender is nominal 240 ohm empty and 30 ohm full. You need a sender with a right hand float swing to mount up to your SAE flange and fit your tank.
To check the existing float, disconnect the sender wire, connect one lead of an ohm meter to the sender terminal and the other lead to ground. Move the float up & down in the tank. The resistance value should be ballpark as above.
Joe
John Saeli
08-08-2004 09:57:05
Hey Lincoln: I replaced the 12V unit on my 350 with a Universal unit from NAPA. Works well.
