David Brown 995 clutch job
Eric
08-07-2004 13:19:49
I'm trying to replace the clutch and throwout bearing on a 1974 David Brown 995. If I'm reading the manual right it seems I will not have to split the tractor to do this, just remove the clutch housing cover. Has anyone out there done this before? Any hints would be much appreciated. Thanks in advance.
Elmer
08-08-2004 13:30:52
 Re: David Brown 995 clutch job in reply to Eric, 08-07-2004 13:19:49
It can be done that way, but is just as easy to split the tractor. Go with a long 3/8 extension with a 9/16 socket under the fuel tank from the rear and loosen the top two bolts at the top of the bell housing. Then undo wiring, throttle, and shut of linkage, and the rest of the bolts and split it.
