help-68 case 680 clutch pressure problems
mike naticha
08-07-2004 06:51:47
68 -680- 2wd with shuttle shift, 4cyl diesel.it drives ok but when you go to push loader into a pile, it slips.i was told clutch pressure gage should read 110 psi , its only around 50.has anyone delt with this before. if so roughly what are we talking in parts and also labor if i took it to someone. i had a 60s 530 with same problem and was told i have to split machine in 2 to fix so i let it go.this on looks like you just pull the motor to get at it. any info greatly appreciated- mike
jcmarleau
08-07-2004 20:11:28
 Re: help-68 case 680 clutch pressure problems in reply to mike naticha, 08-07-2004 06:51:47
It could be at least from 1 to 8 different thing you have a torque in this unit you have forward and reverse clutch and you have torque pump and you have metal seal around the piston so many different items and unless you do a pressure test it is anyone guess the parts and price involve that you will have to spend . You definetely have to split the tractor once you find out what pressure you have on the torque or the pump etc. Now one important part is you are sure of the model because Case 680CK and 680CK -B 6+80CK C 680CK E 680CK G etc. what I mean read the serial number plate to make sure since all 680 Case Series Bachkoe is Trademark CK stand for Construction King. if any further question my e mail is [email protected]
