case 350 3 point hitch arms
Bill Carr
08-06-2004 15:18:18
Any one have a set of arms for a case 350 other models may fit but have not got to a parts manuel to verify which ones but suspect 300 400 600 may be the same any help is appreciated Thanks Bill
VAC Lee
08-09-2004 09:49:45
 Re: case 350 3 point hitch arms in reply to Bill Carr, 08-06-2004 15:18:18
If you still need a set hitch arms email me. I have a 350 that I am parting out the hydraulic system and pto parts on it.
Bill Carr
08-11-2004 17:15:57
 Re: case 350 3 point hitch arms in reply to VAC Lee, 08-09-2004 09:49:45
Vac Lee what condition are your arms in and how much? Also do you have a radiator grill. Thanks Bill Carr
VAC Lee
08-13-2004 13:24:14
 Re: case 350 3 point hitch arms in reply to Bill Carr, 08-11-2004 17:15:57
The left one is in very good condition. The right one has been repaired where the arm attaches to the pivot. It is a decent repair, not butchered. They do not appear to be bent. They do not have the latches or locks. The price is $125 plus shipping for the pair. I do not have any grille parts.
bill carr
08-16-2004 17:36:49
 Re: case 350 3 point hitch arms in reply to VAC Lee, 08-13-2004 13:24:14
VAC LEE my email is [email protected]. will be out of town for a couple of days. If my Dad did not get a set for me will contact you and buy yours. thanks bill
Glenn/MN
08-06-2004 15:37:01
All 300's should fit not sure of the B series PTO cover for a 350 is really different than the rest of them as well as the obvious engine components, I looked for a long time finally got a complete salvage tractor out of Michigan, good luck
Bill Carr
08-07-2004 06:47:50
 Re: case 350 3 point hitch arms in reply to Glenn/MN, 08-06-2004 15:37:01
Glenn thanks for reply I dont believe that all 300 series arms will fit. I know that the 300b arms are straight where as my 350 arms are curved .they start out narrower near the tractor then widen at the draw bar end . The inner arm bushing support is actually made into the main tractor frame the outer side is a bracket bolted thru the axle. Many other models use straight arms with two bracket bolted thru the axle to hold the arms. thanks for your thoughts, Bill
