470 couple questions
bball
08-05-2004 16:01:38
1972 Case 470 diesel
1. I don't have a manual yet... What is recommended for motor oil, hydraulic, transmission, rear endand power steering?
2. Previous owners cut out A LOT of wiring. Anyone have a wiring schematic or familiarity w/ how it should be? No lights and the temp gauge isn't working. Apparently the temp gauge has wires coming off the back of it(some are cut off)and no metal wire that runs up into he engine to read temp. Is this normal or do diesel temp gauges work differently?
3. The seat slants back unless you put a block under it. It still has all 4 little arms that hold the rails for the seat, but everything swivels from front to back... Is there a way to tighten this up so I can lose the block?
4. I want to put a heater in the block for winter, what, where and how do I go about it?
Thanks for any help and sorry for the long post.
Brad
JCmarleau
08-05-2004 20:43:29
 Re: 470 couple questions in reply to bball, 08-05-2004 16:01:38
Have a part manual if this could be of any help my e mail is [email protected]
bball
08-06-2004 08:22:04
 Re: 470 couple questions in reply to JCmarleau, 08-05-2004 20:43:29
i sent you an email.
