Searching for a Marvel Schebler TSX-43 Carburetor
John P. Martine
08-05-2004 07:55:50
I want to put a Marvel Schebler TSX-43 carburetor on my '41 Case VC. Presently, the tractor has a TSX-33 off of a Ford 8N or 9N tractor and the carburetor does not bolt up to the manifold with both bolts of the same size. It has a stove bolt holding it on one side. Anyway, I bought a TSX-43 core from a salvage yard in Western PA sight unseen and sent it to a carburetor rebuilder, Farmer Services in Leetonia, OH, Randy Farmer, a really nice gentleman! Well, ages ago, the carburetor bowl with the brass tag still on it had been switched out with a different upper assembly section. Long story short, I'm back to the drawing board again. Randy Farmer tells me that this search may well be a hard search. If anyone has knowledge of the whereabouts of a "tagged" TSX-43 with the throttle controls on the left and with the screw adjustments located on the right as you hold the carburetor in your hand, with the air intake pointed toward you, please get in touch with me. I read Case and Allis posting EVERYDAY! I'm also leaving my email address exposed if you wish to contact me directly. If you contact me directly, I can not check my e.mail other Fraiday because I'm off for the weekend from work. Thanks in advance you all of your interest and assistance. --JPM
Jerry W
08-14-2004 17:13:17
 Re: Searching for a Marvel Schebler TSX-43 Carbure in reply to John P. Martine, 08-05-2004 07:55:50
I have a carb TSX43 in my hand and when the intake/choke port is facing me the throttle and fuel port are on the left and the idle mixture and choke are on the right.
Remember that it is a bare carb body as most removable pieces have been removed.
If you live in the continental USA I will ship the carb for $25.
Email me - my email is open.
Jerry
Jerry W
08-08-2004 14:37:39
I do not have a complete TSX 43 but I do have a nice upper and lower body for one. All removeable parts have been removed.
I would sell them. Email me if you are interested. I am in western Wisconsin.
Jerry
John P. Martine
08-09-2004 11:53:35
 Re: Searching for a Marvel Schebler TSX-43 Carbure in reply to Jerry W, 08-08-2004 14:37:39
...that upper piece, does it have the linkage controls on the right or on the left side of the carburetor as you are holding it with the intake pointed toward you? How solid is the flapper control? With orientations as noted above, where is the needle valve? --JPM
Jerry W
08-09-2004 17:28:01
 Re: Searching for a Marvel Schebler TSX-43 Carbure in reply to John P. Martine, 08-09-2004 11:53:35
John I dug into my TSX barrel of boned out carbs and found the following 4 types of top casting.
I do not know for sure which top may have come with the bottom. I was original putting them together judging from coloration.
1. Linkage, feed and idle mixture on right
2. Linkage on right - feed and idle mixture on left
3. Linkage and idle mixture on right - feed from either
4. Linkage and feed from left - idle mixture on left
John P. Martine
08-11-2004 14:01:33
 Re: Searching for a Marvel Schebler TSX-43 Carbure in reply to Jerry W, 08-09-2004 17:28:01
Looks like I need throttle control on the left and choke control on the right ... with air intake pointed toward you as you are holding it. Prefer needle valve access on right. (Presently, the rebuilt TSX-43 I just bought (and paid for rebuild) has one needle valve on the left (on the engine block side) and one in center 180 degrees opposite the air intake.--JPM
Keith-OR
08-06-2004 00:46:15
You might check with Jerry W at or near the bottom of page. He has a post " Where can a guy see a list for Schebler Carbs". Seems that he has some carbs and possibly have the one you need. HTH Keith
