D and C rocker arms
Dean Meissner
08-04-2004 17:04:38
With so many things on the D and C being similar, anybody ever try to retrofit the rocker arms and shaft from a D to a C to allow for lubrication. It easy enough to tap into the oil lines down below. If everything else is the same as far as rocker arm angles and lengths then all that would be needed is a connection to the oil tube. Any thoughts or things I may have overlooked?
wilson
08-06-2004 19:58:48
 Re: D and C rocker arms in reply to Dean Meissner, 08-04-2004 17:04:38
I did on my 37 cc puller with 6128a head also added oil pressure guage
DKase
08-05-2004 05:39:44
I did that on my CC. I tapped into one of the oil lines in the oil pan and ran a line up past the push rods and press fit the line into DC rocker arms. Its been about 3 years since I did this and it seems to be working fine.
