Case not shifting
ryan
08-03-2004 20:47:15
I have a case 541. the pin sheared on the gear shift and it seems to be stuck with 2 gears engaged. the 2 rods on the left side of the box are all the way back, the right rod is centered. i cannot lift the top off but can get the back to lift about 1 inch. the shift rods do not move by tapping on them. Any suggestions on what to do would really be appreciated. --Thanks--
Lew
08-03-2004 20:56:55
 Re: Case not shifting in reply to ryan, 08-03-2004 20:47:15
When I had my VAC in two gears at the same time, I also had great difficulty in removing the cover until I jacked up one rear wheel so I could rotate it slightly and took some pressure off the forks. It worked for me, maybe it will work for you.
Sherman Kirchmeier
08-05-2004 20:25:37
 Re: Case not shifting in reply to Lew, 08-03-2004 20:56:55
I can not get tractor to shift into reverse. All gears work except reverse still goes forward
