Taking Part Numbers to the Dealer
Ryan
08-03-2004 20:35:05
So I am finally getting my VAC-14 back together and I am going to be needing some gaskets. I plan to go to my local CaseIH (used to be a Case dealer) to get the necessary parts if they are still available. I have the part numbers from my parts manual but I am sure they are most likely outdated by now. How do you guys convert the old numbers to the new ones?
Keith-OR
08-04-2004 07:07:23
 Re: Taking Part Numbers to the Dealer in reply to Ryan, 08-03-2004 20:35:05
Ryan, was just at our local CaseIH yesterday, checking on availability of head gasket for VAC 14. It did not show up in their books. Told me they would have to go with after market gasket. Hope you have better luck than I am having. I stll haven't found a block for the VAC that I am working on. Might have to see if I can get it line bored..... Keith
Brian
08-04-2004 15:26:32
 Re: Taking Part Numbers to the Dealer in reply to Keith-OR, 08-04-2004 07:07:23
Try your local NAPA auto parts dealer, you might have luck there.
C. Amick
08-04-2004 09:37:29
V A L U - B I L T Tractor Parts has VAC full engine gasket sets, head sets, or just the oil pan gasket. Don Livingston probably has them as well. O T T O Gas Engine Works may also have them.
Ryan
08-04-2004 07:13:47
Keith,
As I said in my email, if you can find some way to get it half way across the country you could darn near have the one that I have lying here.
Keith-OR
08-04-2004 07:52:10
 Re: Taking Part Numbers to the Dealer in reply to Ryan, 08-04-2004 07:13:47
Ya Ryan, got your email. But am not headed your way. Just ship it to me airmail....:) :)
Thanks for the offer....Keith
Jim Handke
08-04-2004 05:54:57
We take old numbers to our dealer, too. New numbers pop up as crossovers and they punch them back in their computer.
Bill-KCKs
08-04-2004 03:55:35
This is spooky. Exactly the same question I was about to ask. What reference book do I need to cross part numbers out of the E61 Case VAC book to modern numbers?? I'm going to have to bite the bullet and replace the torque tube shaft seal and the bull pinon shaft seals. Not exactly looking forward to it. Pretty obvious my hydraulic fluid is going somewhere it shouldn't.
Paul f
08-04-2004 08:59:29
 Re: Taking Part Numbers to the Dealer in reply to Bill-KCKs, 08-04-2004 03:55:35
Bill: If by bull gear pinion you mean the seals on the shaft for the brakes (VT3465) I just last week got 2 from Case (Number crosses to A30501 which in turn has been replaced by 169948C91) I wound up with one of each. Newer one is a little thicker but there is plenty of room.
A30501 is National 450316
169948c91 is National 470316
The seal in my tractor was Victor 62440
caseman-d
08-03-2004 20:56:33
If you don"t have to many email them to me and I"ll check them out for you.
caseman-d
