Fuel shut-off on 530
dan (nj)
08-03-2004 04:50:46
I don't think i'm crazy, but the fuel shut-off (to turn the engine off) on a 530 backhoe, is a knob you pull out, right? To start the engine, you push it in and to stop it, you pull it out. Has anyone ever heard of the reverse (pull out to start and push in to stop)? Thanks, Dan.
dan (nj)
08-05-2004 04:29:20
 Re: Fuel shut-off on 530 in reply to dan (nj), 08-03-2004 04:50:46
Thanks, one and all for your help. One more question, does anybody know where I can go to buy the time to work on it? Dan.
Klyde
08-03-2004 17:23:41
Yup. Had one off and sent in to be repaired and thats the way it came back. Lever was on upside down, I sent it back an they put it right.
dan (nj)
08-04-2004 04:05:35
 Re: Fuel shut-off on 530 in reply to Klyde, 08-03-2004 17:23:41
So how do I know what position it SHOULD be in? We are trying to bleed the pump and have no idea when the fuel is off or on. We're wasting a lot off amps cranking the starter. Thanks, Dan.
C. Amick
08-04-2004 11:36:20
 Re: Fuel shut-off on 530 in reply to dan (nj), 08-04-2004 04:05:35
The tractors that I have seen that "pull out to run" have a notch or slot that the rod sits in to hold it out to prevent the operator from bumping it and killing the engine. If your's doesn't have a mechansm to hold the rod out, I would guess it is set up for "push in to run".
Tom (Ks)
08-03-2004 17:10:58
A/C tractors used to pull out to start, in to shut off.
