model c fuel
c-case
08-02-2004 18:45:44
I recently got my model c back together, and running. Although it seems to take a lot of gas.
I put about 2 gallons into the small partition of the tank, and started it up. I ran it for about 30 to 45 minutes, while making adjustments to the carb.
then it stopped running, I was out of gas. this seems like an excessive amount of gas usage to me.
Does anyone out there have an opinion on this??
Thank You
c-case
c-case
08-03-2004 12:42:51
 Re: model c fuel in reply to c-case, 08-02-2004 18:45:44
THANKS GUYS
I WILL CHECK THAT OUT
C-CASE
Brian in Ohio
08-03-2004 07:04:28
Sounds to me like the partition between the two tanks has a leak, and the fuel is running into the main tank. I know my 36 C will run a long time on just a little gas.
Gene Dotson
08-02-2004 19:19:22
Did you check your main tank to see it the selector valve is leaking and letting fuel go the main tank?.. Gene
