Case 630 won't start
Joe M
08-02-2004 15:58:59
Hi All. I have a Case 630 - a beauty - the other day I could no longer start it. I charged it (which is not abnormal) and the starter now clicks once or twice each time I turn the key. The lights seem to work. I even tried to boost it. I have tickle-charged it for days now and nothing new. The battery connections seem ok at each end. Any ideas?
This could only happen on hay-baling day! :)
Joe M
08-05-2004 05:33:38
 SOLVED!: Case 630 won't start in reply to Joe M, 08-02-2004 15:58:59
Hi all - thanks for your comments. Your advice made the difference! I cleaned every connection and the ground. It starts as good as ever. The connection at the solenoid seemed to be the main problem. Thanks so much for all your help!
mikes'600
08-02-2004 18:39:47
 Re: Case 630 won't start in reply to Joe M, 08-02-2004 15:58:59
Sounds like your switch is bad. Try jumping the starter to rule it out.Take a cable from the positive terminal touch it to the power lug on the starter, may spark , but the starter should turn over.If that is ok check your solinoid(spelling) jump off the positive side of the battery to the starter side of the sol. this should turn the starter if it is working ok.If these items are working fine you have a switch problem or a wire problem.
Tom (Ks)
08-02-2004 18:30:18
If your 630 has a neutral start switch on the top of the trans case, check the two wires and the switch. If your battery cables connections are good (from Jay and John), just might be a bad starting circuit.
Jay
08-02-2004 16:53:46
My case is a positive ground make sure your hooking the charger up correctly.
MAJohn
08-02-2004 18:24:15
 Re: Case 630 won't start in reply to Jay, 08-02-2004 16:53:46
Make sure your ground connections are good also. The strongest battery in the world won"t move a starter if the juice can not get to ground.
Dave A
08-04-2004 16:36:26
 Re: Case 630 won't start in reply to MAJohn, 08-02-2004 18:24:15
If the above check out good it could be the contact points inside the solenoid. Takes a bit of care but its fairly straight forward to open it up and clean the bolt heads and contact bar.
