600 case terra track bulldozer
Dave Ahlgren
08-01-2004 13:26:53
I have a case 600 bulldozer that heats up after using it for a short time.I put a new radiator and thermostat on it,fan belt is good and tight,takes no extra antifreeze when it starts to heat.Can someone help me as to what to look for?When I take the cap loose I do not notice any water ciculation,is this normal?Thanks for any help,Dave A
george md
08-01-2004 20:13:21
 Re: 600 case terra track bulldozer in reply to Dave Ahlgren, 08-01-2004 13:26:53
Dave, There is a possibility that the impellar either broke or is loose on the pump shaft. Also
the inner liner of the lower rad hose can come loose and shut off the water flow , and there is the chance that there is a crack in the head that
only leaks with compression or when hot, but that
should make bubbles.
There is a case terratrac group on yahoo
link, poke here
george
george md
08-01-2004 20:15:20
 Re: 600 case terra track bulldozer in reply to george md, 08-01-2004 20:13:21
try again
Tom (Ks)
08-01-2004 20:10:19
I have seen the impeller slip on the waterpump shaft, broken impeller and a air lock in the engine.
george md
08-01-2004 20:17:39
 Re: 600 case terra track bulldozer in reply to Tom (Ks), 08-01-2004 20:10:19
Sorry for the same thoughts, we were typing at the same time
george
