Case 446 value
James
07-31-2004 21:45:58
I have been looking for a smaller tractor now that I am down to just 2 acres and came across an ad for a Case 446. I have not seen it yet but I am told it has the mower deck, tiller, and blade. He says it is all hydraulic, and the original engine (20hp) was replaced not long ago with an Onan 25hp. Any idea what it is worth? He is asking $1500. That seems to be high for a tractor that could be very old, but I wasn't sure. Any help would be appreciated.
John H-WI
08-01-2004 13:44:59
 Re: Case 446 value in reply to James, 07-31-2004 21:45:58
The 446 never came with a twenty hp motor. The 6 in 446 is for 1 16 hp. Not that it makes a difference as long as he has changed the engine. Didn't know Onan made a 25 hp for mowers as they aren't being used much anymore. Ingersoll has switched to Briggs according to their website and JD uses Kawasaki in much of their bigger tractors. Biggest problem with this unit (if they had problems) was the clutch on the front, the hydraulic pump, and starter selanoid. I had an 83 446, 85 448, and 88 448. Replaced the clutch part on my 88 and went through several selanoids over the years. The other thing is many of the older units didn't have holdback valves which means they can be freewheeling going down hills. It came standard on the 84 or 85 models. Tillers are expensive attachments to buy so this makes it worth more. Some parts are available yet from Ingersoll and bearings for the mower and front wheels are available from any parts house that deals in bearings. Well worth a look!
Engineer20
08-01-2004 08:47:55
James,
The tractor itself could easily bring close to $1000.00 if it's in decent shape. Having the extra attachments drives the price up even more. There are usually a few on Ebay that bring between $700.00 to as high as $2000.00 if it has a 3-point and several attachments. Hope this helps.
Mike
