Need a power nozzle for a VAC TSX 114 carburator
Jerry W
07-31-2004 20:21:23
Does anybody know where I can get a nozzle for my carburator. It has old Case number 47-589. I have heard it referred to as a power or feed nozzle. The parts book merely calls it a nozzle.
I have sent emails to about a dozen tractor carb people and have gotten no response. Everybody says theat someone makes them but I can not find out who. I bought 2 kits that were supposed to come with them but neither did. I have 2 carb and they both could use one.
Thanks Jerry
C. Amick
08-04-2004 09:41:11
 Re: Need a power nozzle for a VAC TSX 114 carburat in reply to Jerry W, 07-31-2004 20:21:23
Don't know exactly what part you are talking about, but have you tired O t t o Gas Engine Works?
Jerry W
08-04-2004 12:25:54
 Re: Need a power nozzle for a VAC TSX 114 carburat in reply to C. Amick, 08-04-2004 09:41:11
I finally found a guy that makes them and I ordered 2 this morning. Not cheap at $25 each but I need them. His name is Dan Clark and his phone number is 573-374-0092. He runs a business rebuilding carburators.
This nozzle is the broonze tube that screws into the bowl at a 45 degree angle and feeds gas into the air stream. Every Schebler that has sat around in pieces more than likely needs one because they are fragile and also stick above the split line of the carb and get bent and they also corrode if water gets into that carb for any extended amount of time.
Jerry
