VAC Spun center Main.
Keith-OR
07-31-2004 10:02:06
Can anyone tell me if I put another main cap. Can and does the motor need to be line bored as with automotive products. Have a VAC 14 with broken crankshaft, found a different crank. But when disassembling found center main had spun. Also what other engine would fit this Tractor? thanks!! All info and help greatly appreciated....Keith
Keith-OR
08-02-2004 12:24:21
 Re: VAC Spun center Main. in reply to Keith-OR, 07-31-2004 10:02:06
Want to thank everyone for all their input and information on which engines I need to look for...
Thanks again.....Keith
Vac Lee
08-01-2004 05:37:32
The 148 engine will bolt in but is 5/16" longer. The sheet metal will still bolt up, but will not line up perfect. The 159/164 engine and the 188/201 engine have a much larger bellhousing bolt pattern and larger flywheel. The starter holes are also cast in the flange of the block instead of just in the bellhousing. The 148 is a very easy swap, and all of the external bolt-on parts will interchange. You will have to use the VAC flywheel. Even the heads will interchange, but the 148 doesn't have the bolt hole for the spark plug cover. You will probably have to trim the rear lip of the oil pan to clear the flywheel. Hope this helps.
Keith
08-01-2004 14:02:19
 Re: VAC Spun center Main. in reply to Vac Lee, 08-01-2004 05:37:32
It is alright on the sheet metel not bolting up completely in line and no bolt for spark plug cover, This is a working tractor, individual just needs it up and running , has no interest in restoration at this time. Thanks for the good info, gives me more options to work with.
Vac Lee
08-01-2004 18:04:57
 Re: VAC Spun center Main. in reply to Keith, 08-01-2004 14:02:19
A little more info. The G-148 engine is the one that will interchange. The 148-B wil not. It is used in the 430 series. The G-148 was used in the 300, and the 300-B. The 400-B also used a 148, but the bellhousing pattern is different.
Roland Barr
07-31-2004 18:30:09
Find an engine out of 600 case combine. It will be 188 cu in with a lot more power, but should fit.
Keith
07-31-2004 21:16:01
 Re: VAC Spun center Main. in reply to Roland Barr, 07-31-2004 18:30:09
Thanks Roland, will start the search.
Keith
Jerry W
07-31-2004 17:50:16
Absolutely needs to be line bored. You are wasting your money if you do not.
Jerry
Keith
07-31-2004 18:05:36
 Re: VAC Spun center Main. in reply to Jerry W, 07-31-2004 17:50:16
Thanks Jerry , kinda thought so. Could not see where anything would be different between auto and tractor. But you never know. Guess I will start looking for another block.
Keith
07-31-2004 10:06:10
My mistake, should have given serial of tractor and engine, just not thinking this morn....
Engine serial # 72-G4181 Tractor # 6000363
Thanks again!!!!!
