Model L Case
Keith Johnson
07-30-2004 20:14:51
Recently brought Dad's L home from the farm we moved from 50 years ago in ND. The serial number is 320295. I'd like to know what year this tractor was built. Also,the remaining paint is orange. Is this correct or was it repainted sometime? Thanks.
Bob
07-30-2004 21:16:03
 Re: Model L Case in reply to Keith Johnson, 07-30-2004 20:14:51
Take the first and fourth digit and subtract 3. ie. 32-3=29.
It is an early Model L as they were introduced in 1929. It should be painted LC Grey but many were later repainted flambeau red.
Kirk-Tx
07-30-2004 20:32:57
I checked the serial numbers under the reseach & info on this sight. They don't show a Case L with that serial number. I'm sure some of these history buffs on this forum will come up with an answer.
Dr Cy Kosis
07-31-2004 07:15:15
 Re: Model L Case in reply to Kirk-Tx, 07-30-2004 20:32:57
That should be a good number. It would have been the 2,295th L series tractor off the line in 29. My 29 L was the 5,134th in 29, so we know production was high enough for his number to be good. Tag should be low on right of front bolster, not on tool box as most old Cases. It also should have an unembossed hood and the oddball governor setup thats independent of the carburetor.
Keith
08-01-2004 20:23:11
 Re: Model L Case in reply to Dr Cy Kosis, 07-31-2004 07:15:15
I'm wondering why you said this would be the 2,295th L in 1929 when the S/N is 320295. Why not the 295th?
Steve (DE)
07-31-2004 09:52:56
Dr. Cy,
I have a 1930 Case L which has the Zenith carb, the gasoline intake manifold, and the late Case 4-CMA magneto. The tractor is now LC Grey, but it was orange in a prior life, and probably grey again before that. I've just gotten this tractor, and am starting to try to figure out how far to go in restoration. Maybe you could help out on a few questions? First, can I fit a Kingston carb to the gasoline manifold? Second, what else do I need to change to go back to the Robert Bosch FU4 magneto? I left my e-mail address visible if you want contaact me directly.
Thanks, Steve
DrCyKosis
07-31-2004 12:01:10
 Re: Model L Case in reply to Steve (DE), 07-31-2004 09:52:56
I don't know what to tell you about the Kingston Carb change back. Mine has the original Kinsgton L3L carb on the original dual fuel intake manifold. The manifold was rotted out and the heatbox has been trimmed away. The exhaust has been changed to a later LA manifold.
The complex part of the swap would depend on what kind of governor setup your tractor originally had. I know the '29s had the weird governor that had a seperate butterfly contained within the intake itself and no connection to the carb at all, but i don't know when it was changed to a conventional governor setup.
As for the RB FU4 mag. I have obtained one for mine to replace the 4CMA someone placed on mine, but havent changed it over yet. It appears to be a direct swap less any changes made to the linkage for the 4CMA to have worked properly.
I can send some pics of what my manifild setup looks like if you'd like.
