dc sides
dan
07-29-2004 19:22:00
what should i use for a dc sides cheap
Paul f
07-30-2004 05:27:45
 Re: dc sides in reply to dan, 07-29-2004 19:22:00
Dan: I am curious as to what you mean by sides. My DC3 has a one piece hood but no separate sides.
dan
07-30-2004 07:38:21
 Re: dc sides in reply to Paul f, 07-30-2004 05:27:45
I have a pulling tractor and i was looking for some side sheilds what you can make them out of that is cheap
chris
07-31-2004 22:02:54
 Re: dc sides in reply to dan, 07-30-2004 07:38:21
Dan just curious how your dc pulls? I pull a 50 dc in the 4500#,5000#,5500# classes, always have the same problem (traction) i have been told by many i should try pulling in heavier weight classes. never pulled against another dc before so it's hard to compare what things to change. thanks
Jerrie Lott
08-01-2004 13:44:19
 Re: dc sides in reply to chris, 07-31-2004 22:02:54
Have you tried pulling in 2nd gear. I have never pulled one but my dad had one he bought brand new in 1954-55 and the torque that thing has is unreal you got to remember that engine is about 252 cu. in. We used have a field that had a very steep gate coming out of it, pulling loads of grain if it would spin out in low I would go back and take a longer run at it in 2nd and the torque would carry it over even though the tractor pulled down to probably 450-500 rpms. Jerrie
chris
08-01-2004 19:42:12
 Re: dc sides in reply to Jerrie Lott, 08-01-2004 13:44:19
I tried pulling in 2nd gear for the first time 3 weeks ago and powered out, the problem was i didn't have the linkage adjusted wright and the rpm's were way to low , i have corrected the problem and will try it again in 2nd gear at the next pull this weekend. thanks
