Hey: 1070 guy
Jim Handke
07-29-2004 17:31:44
Looked up the pto in our manual and it shows an o-ring that goes on the shaft that the pto shaft pushes against when you install the shaft for 1000 rpm. That's the only thing I see that keeps oil from coming out around the shaft. It looks like you'll have to pull the pto housing off to fix this. Sorry I took so long to get this to you.
1070 guy
07-29-2004 21:10:33
 Re: Hey: 1070 guy in reply to Jim Handke, 07-29-2004 17:31:44
thanks jim, i figured there must be something else that was allowing the oil to drip out from under my pto shaft. there are 4 nuts holding the housing on but i didn't want to just pull it apart in case something falls inside.i will go to my dealer, order the o ring, and maybe see an exploded view so i know what to expect.thanks again.
Shane
08-01-2004 10:04:13
 Re: Hey: 1070 guy in reply to 1070 guy, 07-29-2004 21:10:33
When you say 4 nuts do you mean just around the pto shaft itself or the whole rearend housing. I am sure you have to take the whole thing off to service the pto from the inside side.
david
07-31-2004 18:25:27
hey guys that o-ring is a real common problem 90 series had the same thing.
Jim Handke
07-31-2004 19:17:35
 Re: Hey: 1070 guy in reply to david , 07-31-2004 18:25:27
Dad has a 970 and I have a 1070, neither one has had that problem. We change shafts several times a year, depending what we hook up. Have we been lucky and can expect to develope that problem down the road?
Shane
07-31-2004 19:52:15
 Re: Hey: 1070 guy in reply to Jim Handke, 07-31-2004 19:17:35
I doubt it is a common problem. The only tractors with the dual pto were the 1070's and smaller and not sure about the 2090 if it is a dual pto or not but only a few 2290's were dual, most were 1000 rpm only. We change from 1000 to 540 on our 1070's (3 of them) many many times a year.
david
08-01-2004 17:55:08
 Re: Hey: 1070 guy in reply to Shane, 07-31-2004 19:52:15
didn't relize the common problem statement would start a fuss.probably changed 6 in the last 7 years the problem doesn't seem to be the use but the lack of.i change my shaft often,. no problem but i trade a few and the ones that set for extended time seem to flat spot the o'ring.
JW
08-01-2004 06:02:54
Shane, All 2090s and 2290's were dual speed as were all 1170's and 1175s.
