VAC Starter switch
Dale
07-28-2004 16:50:31
Where can I buy a new push botton starter switch for a VAC Case?
mj
08-01-2004 16:49:36
 Re: VAC Starter switch in reply to Dale, 07-28-2004 16:50:31
Take it apart and clean the contacts.
Joe (Wa)
07-29-2004 11:37:42
Starting switch original p/n VT3588, cross ref to G13047.
G nr is an active Case p/n. Check with a Case dealer, it may be a substitute (not as original but replacement for?).
Joe
C. Amick
07-29-2004 09:46:23
Have you tried a Case/IH Dealer? If you find on that used to be a Case Dealer, he should have the correct part number. Where are you located?
