On LA, Can I tighten Bull Gear Nut Going In From T
TMAC
07-28-2004 12:58:10
At one time I had removed the back cover from the rear end of my '49 LA to see if I could remove the axle and hub from the inside(I couldn't) but after I had buttoned everything back I noticed the axle had moved about 3/4 of an inch out and now the rear axle leaks. Instead of doing it all over again can I remove the trans cover and tighten the nut from the topside?
DCTOM
07-28-2004 14:18:11
 Re: On LA, Can I tighten Bull Gear Nut Going In Fr in reply to TMAC, 07-28-2004 12:58:10
TMAC-- DONT THINK SO HARD TO GET THE TAB ON THE LOCK FROM UP THERE, BETTER TAKE THE BACK OFF, SEEMS EASIER THAN REMOVING GAS TANK AND ALL, TOM
