Case L Front End Parts
Jim Mitteer
07-26-2004 19:49:26
I need the front end casting that the front axle attaches to for my 1935 model L. Any sources in Michigan or the midwest?
steve
07-27-2004 03:47:00
 Re: Case L Front End Parts in reply to Jim Mitteer, 07-26-2004 19:49:26
If you find a source for parts I'm looking for kingpin set for 48 LAI would appreciate it if you passed on information. Thanks
Leland
07-26-2004 22:46:11
Youi would'nt be the person that came down to ILL and bought the old L we had with the same problem?
Jim Mitteer
07-27-2004 00:36:47
 Re: Re: Case L Front End Parts in reply to Leland, 07-26-2004 22:46:11
I bought it from a fellow in Grand Rapids, MI. He probably is the one who got it from you. He told me he bought it in Illinois.
Any information you can share with me regarding the tractor would be appreciated.
Leland
07-28-2004 20:26:11
 Re: Re: Re: Case L Front End Parts in reply to Jim Mitteer, 07-27-2004 00:36:47
Jim found out a little more about your L, you are the 3rd owner wifes grandfather bought it from a bank during ww-2 and had it ever since. They thought it was purchased new in Windsor ILL from a dealer there and guy bank took it from did'nt make it home from war only one person alive that knows about this old beast.I wish you the best of luck best wishes Leland
Leland
07-27-2004 09:39:36
If it was ours father inlaw said it was a 36 not a 35and if it was ours , should have a goodyear longbar shortbar tire on left rear and new 4rib tires on front if you have our old tractor I can help a little
Jim Mitteer
07-27-2004 18:27:53
 Re: Re: Re: Re: Case L Front End Parts in reply to Leland, 07-27-2004 09:39:36
Yes this is the same tractor. It runs good but I have to pull it to start...only about 3 feet and it fires up. It has a high speed rear end and a plastic CASE sign on the side of the gas tank.
JIM
Leland
07-27-2004 19:10:07
 Re: Re: Re: Re: Re: Case L Front End Parts in reply to Jim Mitteer, 07-27-2004 18:27:53
.I am glad she has a good home. If you want to slow her down you will have to change sprockets in rear end and take a couple of links out of drive chain And ray said front end had been like that for many years and his dad had no problems that I know of. Ray thought the mag needed rebulit maybe thats why you have to pull her
