VAC CASE NO POWER
KEN BARTOS
07-26-2004 16:24:15
THE ENGINE RUN VERY GOOD AT IDLE AND HIGH RPMS BUT WHEN YOU GO IT FALL FLAT ON IT FACE CANT EVEN GET UP A SMALL HILL THE ENGINE WORK THAT HAS BEEN DONE A NEW CARB POINTS WIRES CAP ROTOR TIMMING CHECKED . FUEL TANK AND LINES AND FUEL BOWEL ALL HAVE BEEN CLEANED COULD THE GOVERNOR BE THE PROBLEM OR IS THE TIRE SIZE TO SMALL 11/24 THE THROTTLE LINKAGE IS ADJUSTED AS PER THE BOOK I THINK I'M AT A LOST.
mj
08-01-2004 16:53:43
 Re: VAC CASE NO POWER in reply to KEN BARTOS, 07-26-2004 16:24:15
What CASEPOWER said and.....do a valve adjustment.
CASEPOWER
07-26-2004 18:18:25
Is it choking out?? or is it just powering down?? Powering down, I would check the timing. Choking out, I would almost guarantee it's not getting enough fuel. To check the governor, just hold the brakes and start letting the clutch out. Have someone watch it to see if it is opening the carburetor up.
