Bad wiring?
Russ in WI
07-26-2004 12:31:59
Nothing happened when I tried to start my VAC-14, so I took the generator off and had it tested, and replaced the battery. The tractor fired right up, but my amp gauge reads "0" all the time. Shouldn't it be charging the battery, or will it read "0" if I am not running the lights, etc? I have an 8 volt battery and figured I could adjust the regulator to 12 amps using the amp gauge, but hit this wall. Also, the wiring is newly re-done and all connections are good. Any advice would be appreciated. Thanks -- Russ
