Case D Serial number.
Andy H
07-25-2004 09:47:35
I Am just restoring a Case model D of 1939 and as i've seen lots of good info on serial no's on this site, i wondered whether anyone could tell me a bit more about my tractor from the serial no.
the number is; 4302187.
Thanks.
DCTOM
07-25-2004 16:11:26
 Re: Case D Serial number. in reply to Andy H, 07-25-2004 09:47:35
ANDY, 4302187- D WAS BUILT JUNE 22 1939 AND SHIPPED TO ASSOCIATED INPLEMENT CO. PALACE OF INDUSTRY WEMBLEY MIDLESEX ENGLAND ON SEPT 15 1939, IT HAD PTO AND STEEL WHEELS GOOD LUCK TOM
maynard storer
07-28-2004 12:53:51
 Re: Re: Case D Serial number. in reply to DCTOM, 07-25-2004 16:11:26
im trying to find the year for a case dc serial number 5205383 dc
Andy H
07-29-2004 13:41:58
 Re: Re: Re: Case D Serial number. in reply to maynard storer, 07-28-2004 12:53:51
5205383 would be a 1948 tractor i think. This is worked out by subtracting 4 from the first two digits of serial no, ie 52-4 = 48. I assume this formula is for all Case 7-digit serial no's.
Hope this helps.
Andy H
Andy H
07-26-2004 13:45:11
Thanks DCTOM and caseman-d. very pleased that i've found that out! She's seen a bit of work since june 22 1939!! I've done the backend and fenders, just about to start on the engine.
one again, thanks.
Andy H
caseman-d
07-25-2004 11:06:20
According to the serial number it is a 39 model. The big question is does it have a 3 speed or a 4 speed transmission. 39 was the first year for them and if memory serves me right the first 500 still had the C 3 speed transmission in them. Also someone posted about the throttle lever being different.
caseman-d
Andy H
07-25-2004 13:17:42
 Re: Re: Case D Serial number. in reply to caseman-d, 07-25-2004 11:06:20
It has a 4 speed 'box in it and the oil pressure and heat gauges are mounted half way up the steering column, along with the control for the cable-operated radiator shutters. The throttle lever is mounted on the right hand side of the steering column, just below the steering wheel. thanks, Andy H.
