DB 990 hydralics problem
Anders
07-25-2004 05:17:48
Hi!
I have a problem with my DB 990. I cant get the lift working. Im not able to lower it, when i try to do that, it goes up...????
What could that be?
James
07-25-2004 11:12:16
 Re: DB 990 hydralics problem in reply to Anders, 07-25-2004 05:17:48
You have probably got the selector set on TCU instead of Height. Look just behind the 3pt control lever. There is a dial selector with 3 positions. The 3pt arms need to be fully raised to move the selector. With the tractor running, lift the arms by pushing the control lever fully rearward against the spring. The dial should then turn to Height.
TCU means traction control and is for draft control when plowing.
Anders
07-27-2004 04:25:57
 Re: Re: DB 990 hydralics problem in reply to James, 07-25-2004 11:12:16
Tank you!
The selector was broken, havent seen it.
