Case L
Jim Mitteer
07-24-2004 19:18:44
I bought a decent running 1935 Case L yesterday and need some information. I am pretty ignorant regarding these unstyled case tractors and have yet to obtain any manuals.
This tractor seems to be geared high. Folks say this is a 3 or 4 plow tractor yet in 1st gear the speed would seem to be too fast to me....and the other gears are almost road gears. Am I missing something like a hi/low range or what? Also I need the casting that is under the radiator and supports the front end. Mine is cracked. Where is a good source in the midwest? Thanks for your patience.
Leland
07-27-2004 14:37:22
 Re: Case L in reply to Jim Mitteer, 07-24-2004 19:18:44
Jim if thats our old L it had road gear installed . But this tractor was used on farm until the early 60s and they used it for plowing. and general field work has sat in shed for last 15yrs last used to run a buzzsaw like I said in my other email if it was our old L send me a picture of thing when you are done with old girl thanks
jal-SD
07-27-2004 07:24:23
Jim, you aren't too far from Ausin, MN, home of Don L. He posts on this board & has a lot of Case parts. He's as honest as an upper midwest summer day is long. Give him a call at 507.433.0073. Morinings are best. His e-mail is [email protected]. Bought lots of stuff from him & have never been disappointed. (My $0.02 worth. jal-SD)
Casenut
07-25-2004 17:52:42
L;s and C's do not have hi low shifting but the L you have must have what was considered threshing gears. They were not meant to have alot of pulling power but used for belt power for the threshing machines. When going from farm to farm it did not take so long to get there which lead to more money in there pocket.
Jim Mitteer
07-25-2004 17:36:31
Thanks for all the information. Can anyone give me a source for used parts in the midwest? I am located in western Michigan.
Thanks,
JIM
Steve (DE)
07-25-2004 06:43:59
There were optional higher gear ratio sets available for the L. I don't remember where I read this, but I know I did. Also, the LI (industrial) came with higher gear ratios, as they expected it might be used on the road, etc. Try to get hold of some of the early Case literature, as I'm sure this stuff is not a secret, just not often needed.
Chances R
07-25-2004 05:59:23
The L series tractors offered different sprockets in the rear end which made them go at different speeds. To me I would think having the high speed sprockets would be cool! Just pull up along side of another L and challenge them to a race!
Brian in Ohio
07-25-2004 10:30:46
 Re: Re: Case L in reply to Chances R, 07-25-2004 05:59:23
I'll race ya on my 38 CC... It has a factory high speed rear end in it. 3rd gear at 3/4 throttle = 40 MPH Definately an interesting ride!
Chances R
07-25-2004 15:44:45
 Re: Re: Re: Case L in reply to Brian in Ohio, 07-25-2004 10:30:46
third party image
I did not know that the old C's and L's had that kind of sprockets in them. I wonder what low gear top speed in your tractor is. Now as far as you wanting to race this time you asked the right person. I use to pull this 1950 Custom, but now I just drag race it. Its pretty darn quick for a old tractor, your looking at 35 to 40 mph in 200 feet. At that point I reach for high gear. Lets try to keep the rubber on the ground and the stacks in the air.
Brian in Ohio
07-25-2004 18:41:10
 Re: Re: Re: Re: Case L in reply to Chances R, 07-25-2004 15:44:45
Mine isn't that quick off of the starting line. You have to ease the clutch into it and get it rolling. Mind you, a C series only had 27 HP at the belt pulley, so to go from a dead stop to a full gallup is a little taxing on the old girl.
This tractor was ordered from the dealership from the city of Middletown, Ohio for the sole purpose of pulling a milk wagon. According to the gentleman that we bought it from, it never spent a day working in a field.
Bill from Wisc
07-26-2004 06:41:00
 Re: Re: Re: Re: Re: Case L in reply to Brian in Ohio, 07-25-2004 18:41:10
Brian Please email me as I have a question about your cc with high geared rear end, thanks Bill
ted
07-25-2004 04:48:28
Someone has obviously tinkered with something. Never heard of a high or low range, only three speeds forward and reverse. How about the rpms?? That old L should only turn about 1100 wide open. The other thing to consider is that someone may have changed the rear sprokets. I know that has happened in the case of DC's, but I am not sure if LAI's had smaller rear sprokets, if they did, someone could have tried a switch. Was the tractor ever et up for pulling? You might get lucky and get DCTom to reply. You can take his info to the bank.
