DB 996 TCU
James
07-24-2004 07:41:04
I used my TCU to plow for the first time, and it worked a heck of a lot better than I could do without it!
Problem is the lift position does not seem to work. I had to move the lever forward to full TCU to get the plow to lift. Then I would pull the lever quickly back to lift and it would stay there long enough to turn around (usually - it was falling gradually).
With the lift not working, it was nearly impossible to get the selector back to "height". I took the plow off before I started and tried shifting the selector back and forth. It seemed to stick half way between TCU and Height. I had to stand on the lift arms and hold pressure towards the TCU side to get the arms down. Then I was able to shift back to Height.
Note: I think my 'latching' valve is stuck all the time. (the one that lets the lift arms fall without an implement attached) Could that be affecting the TCU operation?
