Case 530 Utility Tractor front wheel
Dennis/Ohio
07-24-2004 03:23:58
Hi, Can't find a 6" x 16" front wheel. Original part# VTA 1303. No longer available. Anybody got one?
Thanks, Dennis....
Dennis/Ohio
07-24-2004 19:30:15
 Re: Re: Case 530 Utility Tractor front wheel in reply to Joe (Wa), 07-24-2004 07:05:28
Joe,
Thanks for the reply and you are correct but I ordered a A29050 and its a 4.5" x 16" rim. The dealer info says its a 6x16 but its not. Bernie at www.newtechparts.com tells me Case is offering the A29050 as a usable replacement but not as a exact replacement. Besides being very narrow the back spacing puts it closer to the tractor frame. It may rub the frame in a turn on uneven ground?
Thanks again, Dennis.....
Joe (Wa)
07-24-2004 20:26:54
 Re: Re: Re: Case 530 Utility Tractor front wheel in reply to Dennis/Ohio, 07-24-2004 19:30:15
Dennis, thanks for the info, I have a 311b with the VTA1303 wheels. Looking in the parts manual they were also used on the 300, 310, 300B, & 400b utility models. Also the 301B, 311B & 411B utility & general purpose models with adjustable axle. There should be some good used ones out there somewhere.
Have you tried Miller Tire? I see he lists a 6x16 wheel.
Joe
