Adding remote to Case 380/DB 885
Art Mathewson
07-22-2004 19:08:47
I just put a remote valve on my Case 380 so I could used the hyd cylinders on my hay equipment. Next to the Selectomatic lever was a block with two plugs. One was labeld "oil supply" the other "oil return" so I plumbed the appropriate hoses from there to the valve. When I started the the tractor though the valve wouldn't have any pressure unless the Selectomatic switch was on TCU and pushed all the way forward and even then the lift arms would come up when I operated the remote valve lever. Anyone have any idea what I am missing here?
Elmer
07-24-2004 03:11:44
 Re: Adding remote to Case 380/DB 885 in reply to Art Mathewson, 07-22-2004 19:08:47
I sent you an email.
