Hey Galen Ishman
SHeiserman
07-21-2004 18:48:36
The dipstick for c-o-m is on the left side in front of rear tires. It'll have a big round cap- can't miss it. Supposed to check it when it's all warmed up and after you shut off engine. It holds 4 gallons. If you go to dealer, they'll sell you Hy-Tran Ultra to put in it.
caseman-d
07-23-2004 11:28:05
 Re: Hey Galen Ishman in reply to SHeiserman, 07-21-2004 18:48:36
I wouldn't use hytran, Use ATF, you will find it will shift better.
caseman-d
SHeiserman
07-23-2004 14:41:48
 Re: Re: Hey Galen Ishman in reply to caseman-d, 07-23-2004 11:28:05
Which type of ATF? Also heard they were going to offer TCH again, which was what was originally recommended. Don't know if it's available or not. If you cross reference far enough, you can use JD HY-GARD, or Champion 4000 Universal, or who knows what else. I don't know what's best.
caseman-d
07-23-2004 19:59:39
 Re: Re: Re: Hey Galen Ishman in reply to SHeiserman, 07-23-2004 14:41:48
On my Case 800 it says to use Type A, which today is ATF. Use dextron 2/3 which is about all the same today. If memory serves me right I thought all TCH was hytran without anti-foaming additive. If your unsure do a search in the archieves for C-O-M as it has been discussed several times before.
caseman-d
SHeiserman
07-25-2004 20:01:11
 Re: Re: Re: Re: Hey Galen Ishman in reply to caseman-d, 07-23-2004 19:59:39
I've seen some past discussions on which was best, but don't think everyone agreed to which type oil (past or present) was best. Hy -Tran seems to work OK. Thanks for your time.
