hydraulics
murray
07-21-2004 16:55:56
I have a 1949 CASE VAC I recently bought, but can't get the hydraulics to work. Belt pulley turns, I changed the fluid - any ideas??
C. Amick
07-22-2004 11:56:15
 Re: hydraulics in reply to murray, 07-21-2004 16:55:56
The cotter pin that goes through the rod at the pump where the control lever rod connects will some times shear off. Moving the control lever should cause this shaft to rotate, if the pin isn't sheared. They are also bad about becoming air locked. Loosen the brass bleed valve and with the tractor running, hold the control lever in the up position until you get a significant amount of oil squirting out. Close the valve while continuing to hold the lever up and see if the hydraulic cylinder moves any. If it moves, push the lever to the down position and repeat.
