VAC Drag Link Parts
Paul f
07-21-2004 06:04:03
Going over the steering system on VAC5451349, I found that I do not have any of the 4 bearings shown in the parts manual (2 at each end between the spring and the adjusting screw)
Part is described as O8630AB Bearing (Tompson 16DB29)
I looked up part number at Depot parts and it cross references to a A30978 but is now called a plug.
Question are these things thrust washers that you can get from many sourcees or are they really something special??? How thick are they? Is there a hole in the center to let the grease through??
Thank You Paul f
R.G.Maynard
07-22-2004 10:22:39
 Re: VAC Drag Link Parts in reply to Paul f, 07-21-2004 06:04:03
These are semi-spherical plugs and have a hole in the middle to let the grease through. I have four if you are interested.
Paul f
07-23-2004 04:28:19
 Re: Re: VAC Drag Link Parts in reply to R.G.Maynard, 07-22-2004 10:22:39
R.G. Yes I am very interested. Please email me (I think I unhide my address)
Paul f
