VAC Engine onto 311 Chassis, WILL IT FIT?
Chuck Sheets
07-20-2004 09:01:04
CASE 311, gasoline, #6051435, has cracked block. A VAC is available. Will the VAC engine go onto the 311 torque tube and and front casting? Will the flywheel/clutch from the 311 fit on the VAC engine?
Any help will be greatly apprecited.
Thank you,
CES
Augie
07-20-2004 09:22:15
 Re: VAC Engine onto 311 Chassis, WILL IT FIT? in reply to Chuck Sheets, 07-20-2004 09:01:04
It's not easy bolt-in. The 148 block is longer than the 124 block.
