530 PTO lube
Ron Fritz
07-20-2004 07:42:40
Can anyone tell me where to fill the pto on this tractor? I just replaced the pto output shaft seal and am trying to refill the pto. Does the fluid go in the upper pipe plugged hole where the adjustor is? This seems to take forever to get fluid in. I'd heard that the trans and pto shared fluid but the trans dipstick shows full. I lost about 2-3 qts. while replacing the seal so I know it is low. Also I've heard that you can run ATF in these instead of gear lube. Can anyone verify that? Thanks fella's.
Tom (Ks)
07-20-2004 19:28:42
 Re: 530 PTO lube in reply to Ron Fritz, 07-20-2004 07:42:40
I would stick with 85-140 gear lube. The only way to fill mine is to go into the adjuster hole.
