Case 1290
colekicker
07-20-2004 07:29:18
Just found a jewel in the rough. 476 hours. Sitting in a barn. So I bought it. But when you run the rpms up it stutters. Sounds like an injector is out. I know this tractor and I know the hours are correct. I just can figure out why it is running the way it is. Any ideas?
Don
07-21-2004 19:48:07
 Re: Case 1290 in reply to colekicker, 07-20-2004 07:29:18
Some of those had a timing retard device on the bottom of the injection pump. You turn it in so it will start easier. If you forget to turn it back out, it will sputter at higher speeds and will not have as much power. Hope this helps.
keith
07-20-2004 19:12:08
Try changing the fuel filters and see if that changes anything if it sat for a while they could be clogged up.
